NAT over VPN Traffic
Answered Question
Sep 14th, 2010
Hello everybody, i need some help in a vpn configuration, this is the problem i need to nat all the vpn traffic because i net to set up a vpn but i already have another vpn with the same network so this overlaps with the new one, so how can i nat all traffic to another network to avoid the network overlaps?.
Please i really need help
Correct Answer by Federico Coto F... about 6 years 6 months ago
Normally you would add:
ip access-list extended INTERNET
  deny ip 192.168.1.0 0.0.0.255 192.168.28.0 0.0.0.255
  permit ip 192.168.1.0 0.0.0.255 any
route-map INTERNET
  match ip address INTERNET
ip nat inside source route-map INTERNET interface FasEthernet0 overload
To allow the 192.168.1.0/24 internet access (except when going through the tunnel).
Try that, but I did notice that the outside interface has a private IP (where the VPN tunnel ends).
Is this tunnel going over the Internet and if so, something else might be NATing the IP then.
Federico.
You're saying the 192.168.1.100 is able to go through the tunnel and to the internet now?
Try adding another....
ip nat inside source static 192.168.1.101 10.10.44.101 route-map VPN
for example.
Federico.
Overall Rating: 5 (2 ratings)
Federico Coto F... Tue, 09/14/2010 - 15:08
  • Green, 3000 points or more
If you have an ASA, then you NAT using Policy NAT, something like this:
Site A:
access-list NAT permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
static (in,out) 10.3.3.0 access-list NAT
Site B:
access-list NAT permit ip 10.1.1.0 255.255.255.0 10.3.3.0 255.255.255.0
static (in,out) 10.2.2.0 access-list NAT
Both internal networks are 10.1.1.0/24 but the VPN communication (after NAT) is between 10.2.2.0/24 and 10.3.3.0/24
Federico.
Enrique Romero ... Tue, 09/14/2010 - 15:24
Hi Thanks, I have an Cisco Router 1711, do you know how to do it in this equipment. I must have PAT for internet access and NAT for vpn traffic.
Thanks a lot
Federico Coto F... Wed, 09/15/2010 - 07:36
You use the same idea that i show you before.
If you need more help please post the networks for both sides and we'll show the configuration commands.
Federico.
Enrique Romero ... Wed, 09/15/2010 - 07:42
Hello thank i really appreciate you help, here are the both site networks
SITE A: 192.168.28.0/24
SITE B: 192.168.1.0/24
I want to nat the segment 192.168.1.0/24 to 10.10.10.0/24 because on the SITE A router i already have another vpn with de 192.168.1.0/24 segment so it overlaps with the new one and i must have internet access in the SITE B router.
Federico Coto F... Wed, 09/15/2010 - 17:13
The configuration varies if you have ASAs or routers as VPN endpoints.
You have routers or ASAs?
Federico.
Federico Coto F... Thu, 09/16/2010 - 15:53
For example:
If the LAN is 192.168.1.0/24 and you want to NAT it to 192.168.2.0/24 when going through the tunnel:
ip nat inside source static network 192.168.1.0 192.168.2.0 /24
Problem with this is that it will translate the network always (not only when going through the tunnel).
If you do:
ip nat inside source static 192.168.1.1 192.168.2.1 route-map NAT
Then you can bind a route-map to specify that the static NAT rule will take effect only when the route-map conditions are met.
Problem is that you will need to do one IP at the time.
In ASAs is a lot easier.
Perhaps someone else have tried this (because I don't see how to apply a route-map when specifying a network in the static NAT).
Federico.
Enrique Romero ... Fri, 09/17/2010 - 08:44
Ok i think i understand you, this is my config
MiniBox#sh run
Building configuration...
Current configuration : 2181 bytes
version 12.3
hostname MiniBox
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
clock timezone Mexico -6
clock summer-time Mexico date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip ips po max-events 100
no ftp-server write-enable
username ***** privilege 15 secret 5 *******
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
hash md5
group 2
lifetime 28800
crypto isakmp key ***** address *****
no crypto isakmp ccm
crypto ipsec transform-set MiniBox esp-3des esp-md5-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
set peer ******
set transform-set MiniBox
match address 101
interface FastEthernet0
ip address 10.1.131.85 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
no cdp enable
interface Vlan1
ip address 192.168.1.253 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Async1
no ip address
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static network 192.168.1.0 10.10.44.0 /24
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.28.0 0.0.0.255
no cdp run
control-plane
line con 0
login local
line 1
MiniBox#
MiniBox#
I'm ok or not? in the acl 101 i must have the nat segment 192.168.1.0 as my permit traffic o my no nat segment?, and what if i want to nat for have internet access?
Federico Coto F... Fri, 09/17/2010 - 10:18
The ACL 101 should be:
access-list 101 permit ip 10.10.44.0 0.0.0.255 192.168.28.0 0.0.0.255
The reason is that since you're translating the 192.168.1.0/24 to 10.10.44.0/24 when going through the tunnel, then the ACL for VPN traffic should specify the translated address as the local network.
Again, I don't see an option of doing this NAT a condition NAT.
If you need NAT for Internet, you can try the following:
ip nat inside source static 192.168.1.1 10.10.44.1 route-map VPN
route-map VPN
  match ip address VPN-traffic
ip access-list extended VPN-traffic
In this way, host 192.168.1.1 will be translated to 10.10.44.1 only when going to 192.168.28.0/24
Try it and see if it works.
Federico.
Enrique Romero ... Fri, 09/17/2010 - 11:30
Hi the first one works perfectly but the second one when i want to access to internet it doesn't work but for the vpn it works, here is my config.
MiniBox#sh run
Current configuration : 2335 bytes
version 12.3
hostname MiniBox
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
encr 3des
group 2
encr 3des
hash md5
group 2
lifetime 28800
crypto isakmp key **** address ******
set peer *******
match address 101
description $ETH-WAN$
ip nat outside
duplex auto
speed auto
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.1.254 255.255.255.0
ip nat inside
interface Async1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.131.1
ip http server
ip nat inside source static 192.168.1.100 10.10.44.100 route-map VPN
no cdp run
route-map VPN permit 10
control-plane
line con 0
login local
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
end
We are really close, thanks for all your help i really appreciate it.
Correct Answer
Federico Coto F... Fri, 09/17/2010 - 11:33
for example.
Federico.
Correct Answer
Federico Coto F... Fri, 09/17/2010 - 11:40
route-map INTERNET
Federico.
