Local Call Route Filter with AUNP
Sep 14th, 2010
Guys,
I am trying to allow only local calls with a route filter using AUNP. My problem is that if i get local calls out the gateway I also allow long distance calls also. I have tried the following with no joy:
Clause   Subscriber Exists
and
Clause  Subscriber == [2-9]XXXXXXX
with each of these filters i can get local calls out but it also allow long distance calls, for example 07 2333 3333, wheres i only want to allow 2333 3333 with this filter.
What am i doing wrong?
Garry
Aaron Harrison Wed, 09/15/2010 - 01:36
  • Community Spotlight Award,
    Member's Choice, May 2015
I'm not an expert on the AU dial plan, but can tell you that the subscriber bit will just match the final part of the number (i.e. the last 8 digits) regardless of whether an area code is present or not. That's how it works in the UKNP from Cisco (more or less)...
What you'll need to do is add additional clauses, something like:
SUBSCRIBER EXISTS
AND
AREA-CODE DOES-NOT-EXIST
And maybe also an extra one for:
SUBSCRIBER EXISTS
AND
AREA-CODE == whatever your area code is
Aaron
Please rate helpful posts...
shgad Mon, 04/28/2014 - 09:53
Hi Aaron,
Are there any commonly used route filters for the Long Distance and International Patterns in the AUNP?
