WCS Report by vendor (device type)
Sep 14th, 2010
I have been asked to produce a client’s report that shows all different vendors (devices type). We have about 10000 users in our system on about 3000 APs (light version) I created a client summary report but encountered some limitations:
If I select any time period over 6 hours, I get the message “The report you are trying to generate contains more than the supported number of records (10000). Change the report criteria to generate a report with fewer records”
If I select a time period of 6 hours or less, I get the report including vendor statistics. Is there any way to differentiate within the vendors by device type? For example instead of the vendor apple, get apple-iPhone, apple-iTouch, apple-laptop, etc.
I would like the ability to create my own reports, by I don’t think it is possible on the Version I’m running. All reports can be customized up to a point, but you still get information you might not care for.
Thanks for any information to overcome these issues.
Jorge Jiles.
Federico Ziliotto Tue, 10/12/2010 - 11:22
Hi Jorge,
It looks like such a level of granularity may not be achievable yet.
Should you need such a feature to be evaluated for potentially being included in future software releases, I would recommend to contact your local Cisco account team.
They should be able to follow up and submit a product enhancement request (PER).
Business units will evaluate PERs and, if feasible for the market, they may consider implementing such an enhancement in future versions of the SW/HW.
Trending Topics - Security & Network
