Arp problem in 6500 and ASA trunk
Sep 15th, 2010
Hi !
I have a problem that I hope any other have  hade and can help me to resolv.
I would like to connect an ASA 5520 firewall to my 6500 LAN-card.
When I connect my ASA to a port on slot 7 as a trunk, it's not possible
to get arp-answer from the ASA. I can see with a sniffer that arp-request and
arp-answer come on the trunk but i don't get no arp-answer on the PC that is
connected to the same VLAN on slot 3 or 5, but if i use slot 7 to connect
my PC all works fine.
The problem is with the arp because when i put arp-antry in my PC manualy
its works to flow traffic to the ASA.
If I use slot 3 that is fibercard to connect my ASA all works fine.
I have no more ideas and hope anyone can help me.
My setup of 6500 i like this.
Slot          card
3              WS-X6415-GBIC
5              WS-SUP32-GE-3B
7              WS-X6148-GE-TX
Overall Rating: 5 (1 ratings)
nicolas.flossmann Fri, 10/22/2010 - 06:19
we have the same problem here with a Linux Firewall connected via a dot1q Trunk on a c6509. If we connect the Firewall and the PC on the same cu-module(WS-X6148-GE-TX) we have problems to get arp answers from the Firewall. Devices on Fibercards get an arp answer from the firewall.
Version 12.2(33)SXI4
Can anyone help?
Giuseppe Larosa Mon, 10/25/2010 - 11:54
Hello Nicolas,
sorry for misleading information looking at the same release notes for another thread I have found out that the linecard is supported
you are fine 6148-AF are listed as supported under the 10/100 linecards category
if you haven't already done I would open a service request  for this issue
Hope to help
ppcisco Mon, 10/25/2010 - 23:35
Thanks Giuslar for that you are engage in this case.
Are you working at Cisco ?
I have still the problem and don't know how to solf it.
Giuseppe Larosa Tue, 10/26/2010 - 03:17
look at Nicolas' last post you may be facing the same issue he refers to a field notice about some specific linecards
if the serial number of your linecars is within the ranges declared in above range you should ask for an RMA (haraware substitution)
no I do not work for  Cisco, people working at Cisco has the Cisco logo near their icon.
Hope to help
ppcisco Tue, 10/26/2010 - 04:52
Yes my card is in that range. Trying to get a new one and hope that it will solve the
I will come back how it works.
Thanks a lot
tqhosting59 Mon, 11/05/2012 - 11:29
Hi, did you get the card replaced?  I think I'm running into the same problem.
ppcisco Tue, 11/06/2012 - 00:27
Hi Mark.
Yes I had got a new card and it works. It's a long time since that so I dont remember all of it.
But it was some problem with small packet, not special witch arp request but to all packet that was
under a specific size, I dont remember the exact size.
Hope you can resolve your problem.
God luck.
nicolas.flossmann Mon, 10/25/2010 - 23:32
Hello Giuseppe,
we believe that we hit the bug described in the field notice:
Field Notice: FN - 26096-WS-X6148-GE-TX,  WS-X6548-GE-TX-May Drop Valid Packets on Egress-Hardware Modification  Has Been Implemented
Two of our modules are affected by this issue. We open a SR and make a RMA for the moduls.
Thx a lot for support,
