bonding in 878
Sep 15th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
What are the mechanisms to bond 2 SHDSL lines (2M/2M) in one link on 878 cisco router?
Can someone give me a standard configuration?
Thanks in advance.
emilio1973 Wed, 09/22/2010 - 23:44
How can i know what is the real speed that synchronizing my bundle line with two shdsl 2M/2M? Add the output of sh controller dsl 0:
CPE251#sh controllers dsl 0
DSL 0 controller UP
Globespan xDSL controller chipset
Line Mode: Four Wire Standard
DSL mode: Trained with SHDSL Annex B
Frame mode: Utopia
Configured Line rate: 4096Kbps
Line Re-activated 1 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
Line 0 statistics
        Current 15 min counters
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 0
        Previous 15 min counters
        Current 24 hr counters
                CRC : 5 LOSW Defect : 0 ES : 5  SES : 0 UAS : 32
        Previous 24 hr counters
                CRC : 5 LOSW Defect : 0 ES : 5  SES : 0 UAS : 0
Line 1 statistics
                CRC : 0 LOSW Defect : 0 ES : 0  SES : 0 UAS : 32
Line-0 status
Chipset Version:  0
Firmware Version:  R4.2.1
Modem Status:  Data, Status 1
Last Fail Mode:  Failed during Carrier Detect status:0x1
Line rate:  2056 Kbps
Framer Sync Status: In Sync
Rcv Clock Status: In the Range
Loop Attenuation:  13.5 dB
Transmit Power:  14.5 dB
Receiver Gain:  27.7420 dB
SNR Sampling:  37.9860 dB
Receive HEC Error Count:  0
Line-1 status
Chipset Version:  0
Loop Attenuation:  13.1 dB
Receiver Gain:  27.420 dB
SNR Sampling:  38.9550 dB
Dying Gasp: Present
Thanks in advanced
