Rewrite header dependent on rserver on Ace 4710
I have a loadbalanced HTTP server which loadbalances between two rservers.
Is it possible to rewrite the http header based on which rserver the request is going to ?
Following is a part of the config to explain.
rserver host guf1
  ip address 10.172.30.21
  inservice
rserver host guf2
  ip address 10.172.30.22
  inservice
serverfarm host guf
  probe HTTP-GET
  rserver guf1 80
    backup-rserver guf2 80
    inservice
  rserver guf2 80
    inservice standby
action-list type modify http STATUS_REWRITE
  header rewrite both Host header-value "status.test.com" replace "guf1.test.com"
policy-map type loadbalance first-match status.test.com-l7slb
  class class-default
    serverfarm guf
    action STATUS_REWRITE
The above works if the request goes to rserver guf1 but if guf1 is unavailable and the request goes to rserver guf2 then I need to replace the Host header with "guf2.test.com" instead of "guf1.test.com"
Is this possible ?
Best,
Gardar Nielsen
jsirstin Mon, 09/20/2010 - 06:27
Gardar,
Unfortunately the ACE cannot rewrite a header based on what rserver that gets the request. Both of the rservers would need to listen for the same host header.
Jim
