SA520 Quick VPN Active Directory
Answered Question
Sep 15th, 2010
Can i check that i have not missed an update and that active directory still cannot be used to authenticate for a QuickVPN / IPSec VPN connection.
Does anyone know if there are any plans to change this and if so when?
Is there any reason why this does not work, is it a security issue or technical issue?
Allan
Correct Answer by rshao about 6 years 10 months ago
If using AD is the objective, you may consider SSLVPN.
SSLVPN does support AD for user authentication.  Pls note it requires license.
The QVPN doesn't support AD today and we will evaluate the possibility for the future release.
Richard
Overall Rating: 5 (1 ratings)
Correct Answer
rshao Mon, 09/27/2010 - 17:23
Richard
