Changing CAS IP address
Sep 15th, 2010
I have configured two CAS to work in HA mode (L3, in band for VPN).
Now I need to change IP address of CAS. How should I do this? Do I need to remove CAS
from CAM, change address of both CAS and then re-add them to manager or can I do address change
directly from CAM (I read that cisco recommends this option). But if I do it from CAM will there be any
trouble with HA because if obviously will not work with old address or does CAM change HA settings too
(to match new addresses)?
Zoran
Faisal Sehbai Thu, 09/16/2010 - 08:01
Zoran,
You'll have to change them on the CAS by hand. CAM won't change the IP addresses on the standby CAS. Also if you're running a later version of CCA (4.7 or above) make sure you look at the certificates closely since if you have them issued to the IP addresses, your HA will break.
HTH,
Faisal
Related Content
