how to disable UDP inspection
Answered Question
Sep 15th, 2010
Hello, I am doing a pre-deployment testing for our new ASA. We are using VeEX tester to generate 10G traffic. Unfortunately, this tester does not have layer 4 traffic support for 10G, all of UDP header, etc. belong to DATA and only can fill 16 bytes pattern (repeat one pattern to fill). This causes ASA to reject package with invalid udp length or invalid UDP port etc. Is any CLI cmd that we can use to disable this UDP checking and passing layer 3 traffic directly? We like to get base performance throughput data.
Thanks in advance.
Correct Answer by Roger Nobel about 6 years 5 months ago
Hi Gongyuan Yao,
You maybe should move your question to the community "Security > Firewalling" since you ask for help on ASA configuration.
Best regards
Roger
Overall Rating: 5 (2 ratings)
Correct Answer
Roger Nobel Tue, 10/12/2010 - 05:16
  • Cisco Employee,
Hi Gongyuan Yao,
Best regards
Roger
