DUC Upgrade
Answered Question
Sep 15th, 2010
My customer in upgrading DOMINO from 5.5.x to 8. So we have to upgrade Unity from 4.0.4 to 7.
DUC installed on Domino server is 1.2.3 and we have to upgrade to 1.2.5.
We have to uninstall DUC 1.2.3 and then Intall DUC1.2.5.  Is there any impact of uninstalling DUC on Domino server?
Does it clean any configuration in Domino server ?
Thanks in advance
Correct Answer by sopayne about 6 years 10 months ago
I found the upgrade guide for Cisco Unity 4.0:  http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/dom/ru_010.html
This excerpt should answer your question:
"Refer to the applicable version of Cisco Unity System Requirements at http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html for a list of supported versions of Domino.
a. Use the Add/Remove Programs control panel to remove DUC for Cisco software from all Domino servers.
b. Upgrade Domino. Refer to the Domino upgrade instructions. "
Overall Rating: 5 (1 ratings)
Correct Answer
sopayne Thu, 09/16/2010 - 09:12
  • Cisco Employee,
