ACS Server certificate export
Sep 15th, 2010
We are in the process of renewing a certificate for our ACS server (v3.2). Is there a way to export the certificate currently in use?
We don't want to lose it if we install a certificate that does not work. We are also exploring using a self-signed certificate, but we're not sure if that will meet our needs.
Thanks!
Yudong Wu Wed, 09/15/2010 - 11:08
You just need to do a backup before install a new certificate.
The backup will include the certificate.
If something goes wrong with new certificate, you can restore the backup which will restore the certificate as well.
aweise Wed, 09/15/2010 - 18:14
Thanks for the info...unfortunately, we tried doing the self-signed certificate, but clients couldn't connect to our wireless network (we use that to authenticate wireless users). We then tried to do a restore from a backup taken earlier this morning and it's still trying to restore - as if something is hung and won't shut down.
This is ACS 3.2 running on a Windows 2003 server.
