How to do a password recovery for a DMP 4400G?
Answered Question
Sep 15th, 2010
Hi guys!:
I have a DMP that was in use but now I need to do some changes and we don't have the login information (username and password). I already try with the reset "button" but nothing happened, is there a way to do a factory reset through console port? Thank you in advance and have a nice day.
Karla
Correct Answer by sdhanral about 6 years 7 months ago
Morning Karla,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
The hard reset on teh DMP-4400 should have worked - Lets try it out one more time as follows :
1)     Make sure the DMP is connected to the DHCP enabled LAN and Powered on.
2)     Turn the DMP around and locate the “Reset” button on the back panel.
3)   Take a sharp object (such as a Pen, etc) and press the reset button.
4)     Here is the key - Keep the reset button pressed for at-least 20 seconds,  release the reset button. At this point you should see both the LEDs solid
5)   Wait for 10-15 seconds - At this point the DMP is restored to factory default.
6)     Try connecting to the DMP usinghttp://> or https:// depending on the code version 5.0/5.1 or 5.2.x
7) The default credentials for 5.0 and 5.1 DMp firmware is admin/default and for 5.2.x firmware is admin/Cisco123
Let us know if this helps.
Sagar Dhanrale
Overall Rating: 5 (2 ratings)
Correct Answer
sdhanral Wed, 09/15/2010 - 08:00
  • Bronze, 100 points or more
Morning Karla,
Sagar Dhanrale
Karla Lopez Thu, 09/30/2010 - 06:46
Hi!:
Thank you sooo much! Is working now . Sorry for take too long to post this message, I was a little busy but your solution worked. Have a nice day.
Karla
yussetamayo Mon, 02/13/2012 - 08:25
hi.
I have a DMP 4400G that was registered on a DMM5.2 version, and i want to upgrade the DMP version to a 5.3 software.
The issue is I dont have the credential to get into the DMP via web, i dont know the ip address, so, i think i should do a hardware reset.
I did the procedure above for the factory reselt but it seems not working. I have the DMP connected to a LCD and nothing appears.
What else can I do?
sdhanral Mon, 02/13/2012 - 08:31
Yusset,
Few Questions :
What happens when you reboot the DMP ?
Do you see a Cisco Splash screen on the TV ?
What is the status of the LEDs on the front panel (right side) - Are the LEDS solid RED and GREEN ?
Do you know if the LAN is DHCP enabled ?
Was this DMP working fine before you resetted it ?
If both the LEDs are solid lit, that indicates that the DMP is unable to get a DHCP address. Have you unplugged the DMP and tried it on a different LAN ? Possibly with different cable ?
How long did you keep the reset button pressed ?
Sagar Dhanrale
yussetamayo Mon, 02/13/2012 - 08:34
Hi Sagar
thanks for your help
I  missed to connect the LAN cable. By the moment I did it, the DMP start to display the home screen.
thanks
Related Content
