ASA 5505 disable commands h323
Sep 15th, 2010
I have to disable the commands below:
policy-map type inspect h323 NO
parameters
policy-map type inspect h323 NORAS
parameters
policy-map global_policy
class inspection_default
  inspect h323 ras NORAS
Was told by a consultant to type no before inspect, but got the error messages below:
Result of the command: "no inspect h323 NORAS"
ERROR: % Invalid input detected at '^' marker.
Result of the command: "no inspect h323 ras NORAS"
HELP!!!!!!!
Thank you,
mojorizn1
fadlouni Wed, 10/13/2010 - 07:59
Hi Bettyann.
sometimes when you mistype something or you are in the wrong config mode, you'll exit back to global config mode, which is not the right place.
you'll have to do it in this order (notice the prompt indicating the configuration mode/submode)
ASA(config)# policy-map global_policy
ASA(config-pmap)#  class inspection_default
ASA(config-pmap-c)# no   inspect h323 ras NORAS
ASA(config-pmap-c)#
Related Content
