redirect results from sh command to text file
Answered Question
Sep 15th, 2010
Hello expert,
I using putty software to access my router.
I would like to copy the result of SH POLICY-MAP INT to a text file for analysis.
The problem I encounter is the display is beyond the screen hence I have to press space bar for further display.
Is there a way I can execute the SH POLICY-MAP INT and redirect the output a text file or remove the more prompt found below the result page.
Jomo
Correct Answer by Lei Tian about 6 years 4 months ago
Try 'show policy-map int | redirect tftp://x.x.x.x/policy-map'
Lei Tian
Overall Rating: 5 (1 ratings)
jomo frank Wed, 09/15/2010 - 10:08
hello Jon,
I tried the command
>> router# term len 0   <--- this will mean there is no prompt and the full output is displayed.
The display is so large that i cannot capture  all the  info by scrolling and  paste  to  a text file .
Is there any method i could use to redirect output
Jon Marshall Wed, 09/15/2010 - 10:15
rbglusers wrote:
hello Jon,
I tried the command
There are quite a few ways to do this but as you have the putty client simply use that to capture the text. See this link for details -
http://itknowledgeexchange.techtarget.com/network-technologies/how-to-capture-a-text-using-putty-client/
Jon
burleyman Wed, 09/15/2010 - 10:39
Also if you want to remove the "more" from a text file just do this in notepad......
Let's say you see this in your text file...
--More--         dot11 syslog
What you need to do is highlight from the beginning of the line to the d
include the spaces at the end of and begining of  --More--
Then right click on what you highlighted and choose copy
Now go to Edit----->Replace
and right click in the Find what box and choose paste
now just clcik once in the Replace with box and leave it blank
Now choose Replace All
and you should be good.
Mike
Lei Tian Wed, 09/15/2010 - 10:59
Hi Jomo,
Another option, you can do; but I think that is more complex than Jon's suggestion:)
3750_2#show policy-map int | redirect ?
  flash1:  Uniform Resource Locator
  flash:   Uniform Resource Locator
  ftp:     Uniform Resource Locator
  http:    Uniform Resource Locator
  https:   Uniform Resource Locator
  nvram:   Uniform Resource Locator
  rcp:     Uniform Resource Locator
  scp:     Uniform Resource Locator
  tftp:    Uniform Resource Locator
HTH,
Lei Tian
jomo frank Thu, 09/16/2010 - 08:06
Hello Tan,
I am interested in your suggestion i attempted to redirect to a remote tftp server see command
router11#show policy-map int | redirect tftp:xxx.xxx.xxx.xxx
but when a check the tftp root direct location on my computer no file is copied maybe i am missing some step in the above command.
Jomo
Jon Marshall Wed, 09/15/2010 - 09:49
rbglusers wrote:
Hello expert,
Jomo
Jomo
In enable mode on your router -
your command goes here
router# term len 24  <-- this just puts it back to normal
Jon
Jon Marshall Thu, 09/16/2010 - 08:21
Can you ping the tftp server ?
Does it have permissions to write the file ?
What tftp server is it ?
Jon
jomo frank Thu, 09/16/2010 - 08:43
hello Jon,
yes i test from within the router
unsure about the question.
Cisco tftp server 1.1
Jomo
Lei Tian Thu, 09/16/2010 - 08:48
Hi Jomo,
Do some quick test.
show policy-map int | red flash:show
copy flash:show tftp:
Are you able to copy the file to tftp srv?
Lei Tian
jomo frank Thu, 09/16/2010 - 09:14
hello Tian,
The test was sucessful . the file was transfer to tftp site
Jomo
jomo frank Thu, 09/16/2010 - 10:06
Hello Tian,
Thanks a million , the command given in your post did the trick .
Keep up the good work.
Jomo
