Cannot login into my VPN concentrator
Sep 15th, 2010
I tried to login to my vpn concentrator today and got "page could not be displayed" The url is https://a.b.c.d/admin and I get prompted with the certificate window and when I click yes it goes to " page could not be displayed " I have tried so many times and no luck. I can ping a.b.c.d - has anyone experienced this before ? BTW, my VPN users can connect fine except that I could not login to make changes. I will appreciate any help. Thanks.
Jennifer Halim Wed, 09/15/2010 - 15:32
Which ip address of the VPN Concentrator did you try to access? The private or the public interface?
Please try to access the other interface ip address if the one that you try didn't work. What did the certificate say?
jeanaguemon Thu, 09/16/2010 - 05:42
I'm using the private. The outside is not configured for that type of connection. The certificate has expired. I tried to install it again but no luck. Thanks.
jeanaguemon Thu, 09/16/2010 - 07:17
Hey Guys,
I resolved the issue myself. This is what I did : I ssh into the VPN concentrator and enable http then I was able to log into it using the browser port 80. Then I generate a new SSL certificate, install and import it. I went back to SSH console and disable http. Now I can use https://a.b.c.d/admin and connect to it. Thanks all for your assistance.
jeanaguemon Thu, 09/16/2010 - 10:46
Hey Guys,
