Changing the Call Handler input on unity
The call handler on unity currently offers users the option to dial their extension at any time, however we are moving from a CUCM AA console to unity 8 and have one .wav file that is already customed for "press 1 to dial an extension".
Is there an option that will allow caller input when press one to hear the prompt " enter your extension" and be able to transfer to the extension.
Jaime Valencia Wed, 09/15/2010 - 12:23
You can lock the digit 1 to send them to another call handler where you play the message you want and they can dial the DN. Or you can send them to a call system transfer if the user is a non-vm user.
If this helps, please rate
When you say I can lock the digit 1 and forward to a call handler and be able to dial the dn, so i can just create any call handler, change the recording and be able to dial extension any time.
For the caller system transfer i can't seem to reach anyone that has a voicemail box and is an internet subscriber is this the way this works?
Also i have a number of internet subscribers to create is there a .csv template I can use to do a bulk import?
jhitt-limited Thu, 09/16/2010 - 05:52
I'd change the caller input for 1 to go to a directory handler.  But you can also change the .WAV file pretty easily too!
