Warning message
getting logs from ACNS
Sep 15th, 2010
Hi All,
           I would like to get logs from ACNS box into my desktop......i can see the log file in this path "/local1/logs", but i'm not sure how to download those logs to my desktop?....any suggestion would be helpful.
Daniel Arrondo Ostiz Fri, 10/15/2010 - 02:49
  • Cisco Employee,
You have two options to copy a file out of a content engine:
  • Use the "CE# copy disk ftp" command to copy the file to an external FTP server
  • Enable an FTP server on the CE itself with the command "CE(config)# inetd enable ftp" and then just connect to it and download the files you need.
Alternatively, you can use the "CE# less " command to check the log file live on the box.
