Getting %PIX-3-305006: regular translation creation failed for tcp src insi
Answered Question
Nov 11th, 2008
I'm getting the error continously for a couple of my hosts on the inside trying to access hosts on a DMZ. For hosts starting connections on the inside to the DMZ, I'm using an access-list. I'm having trouble figuring out what is going on.
Correct Answer by husycisco about 8 years 7 months ago
Hello Sean,
Try this
static (externaldmz,inside) 192.168.151.0 192.168.151.0 netmask 255.255.255.0
Overall Rating: 5 (1 ratings)
Correct Answer
husycisco Wed, 11/12/2008 - 01:24
  • Gold, 750 points or more
Hello Sean,
Try this
Fernando_Meza Wed, 11/12/2008 - 02:13
Hi ..
by looking at your config you probably need to add those hosts you are talking about to the access-list nonat. For instance if the inside host having the issue is x.x.x.x then your entry should look like this
access-list nonat permit ip host x.x.x.x host
Please rate helpful posts !!
