mrmoothe Wed, 09/22/2010 - 06:14
Hi Jonathan,
You really need to give us more than that to be answer you to the full extent.
First of all... what is the current config on the router?
Is there a LAN already configured?
Which portion do you need help with?
Which interfaces are you using in your setup? What is the inside interface and what is the outside interface?
If you can say attach your current config and tell me your exact needs ... we can take a shot at resolving your problem...
--Manas
mavespig Fri, 10/22/2010 - 03:42
  • Silver, 250 points or more
Hi Jonathan,
Configuration steps for HWIC-CABLE are documented here:
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_6xe/snwshoe1.html
However, I don't see 3660 listed as supported platform:
Table 1     Cisco Router Support for WICs and HWICs
Cisco Router
WIC
HWIC
8151
Note The  HWIC-CABLE-D-2 is a fixed-configuration card and is not field  replaceable. The HWIC-CABLE-D-2 card operates only in WIC mode with  8-Mbps throughput.
Yes
No
1800
No
Yes
IAD24311
Yes
No
26911
Yes
No
2800 series
No
Yes
3700 series1
Yes
No
3800 series
No
Yes
Cheers
Marco
