How do you find the EPS or EFS for MARS 4.3.4 (2804)
Sep 15th, 2010
I need to find out the Events Per Second and the Event Flows Per Second.  How do you get that off the MARS CS-MARS-200-K9 unit.  I'd like to find out what I'm getting without having to run reports on the system.  It's very slow.
Scott Fringer Thu, 09/16/2010 - 16:49
Dave;
  Through the CS-MARS GUI, you should be able to navigate to:
ADMIN>System Maintenance>View Log Files
  Set the time frame to ~30 minutes, and the source to Backend and Submit.
  You will likely need to extend the number of events per page.  You can then search for an event of the format:
/process_inlinerep_srvThread 81099696:Total Events + Netflow Rate: 1.574999, Netflow Rate: 0.000000, Running Avg Events + Netflow Rate: 0.090252, Running Avg Netflow Rate: 0.000000
  This should let you know the event rate the CS-MARS is seeing.  Under normal operation, these messages are generated roughly every 10 minutes.
Scott
