Help vpn asa
Sep 15th, 2010
I cannot get my VPN client v5 working with my
asa, everytime i try to connect I get "the remote peer is no longer responding" reason 412
Here is my config
ASA Version 8.3(1)
crypto ipsec transform-set certvpn esp-aes esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 50 set transform-set certvpn
crypto dynamic-map Outside_dyn_map 50 set reverse-route
crypto map crymap 90 ipsec-isakmp dynamic Outside_dyn_map
crypto map crymap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
telnet timeout 5
ssh outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
group-policy testvpn internal
username sconnor password wKwo98zQw2rfpBx/ encrypted privilege 15
tunnel-group testvpn type remote-access
tunnel-group testvpn general-attributes
address-pool VPN-Pool
default-group-policy testvpn
tunnel-group testvpn ipsec-attributes
pre-shared-key *****
My VPN client is setup for group = testvpn and preshared key matches on asa
Any ideas would be great
Nagaraja Thanthry Wed, 09/15/2010 - 15:49
I do not see any group policy attributes defined. Can you please try the following:
group-policy testvpn attributes
  dns-server value
  vpn-tunnel-protocol IPSec
Hope this helps.
