Cisco 1841 Issue
Sep 15th, 2010
I'm no expert in Cisco, but I wanted to get a simple config up and running so I can test a new connection that was just installed. Basicaly this router will connect one of the ethernet interface to the NTU and the other will just connect to a laptop so I can test the upload and download speeds of the new connection..
I have setup the router with what I hope is somewhat correct and also applied the 9.3Mb shapping policy that the ISP told me to. Now my problem is that once everything is hooked up I still cant access any the net, I believe that its has something to do with the routin. Also is it normal that when setting up the interfaces it doesn't ask for the Gateway IP??
Heres the running config
Building configuration...
Current configuration : 1060 bytes
version 12.4
hostname router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$nPs.$B5pZUjaXaQPJ13d9RMi8T/
enable password xxxx
no aaa new-model
no ip routing
no ip cef
ip name-server 139.130.4.4
ip name-server 203.50.2.71
archive
log config
  hidekeys
policy-map shape-all
class class-default
  shape average 9300000
interface FastEthernet0/0
description $ETH-LAN$
ip address 10.10.10.1 255.255.255.0
no ip route-cache
speed auto
full-duplex
no mop enabled
interface FastEthernet0/1
ip address 120.xxx.xxx.10 255.255.255.252
no ip route-cache
duplex auto
speed auto
service-policy output shape-all
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 120.xxx.xxx.9 permanent (This is the GW IP that the ISP gave me not sure if this route is correct)
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxx
login
scheduler allocate 20000 1000
end
As I said this is just a basic setup to get some quick testing done, I will get this setup by a professional once I'm happy that the connection is providing what its ment to
Cheers
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 09/15/2010 - 17:07
You need to add NAT configuration to your router because 10.10.10.0/24 addressing is not routable on the internet. Add this to your config -
int fa0/0
ip nat inside
int fa0/1
ip nat outside
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
ip nat inside source list 101 interface fa0/1 overload
Jon
