BGP and OSPF Stable
Answered Question
Sep 15th, 2010
How can I verify if OSPF is stable between sites? What are parametrs that I can verify?
How can I verify if BGP is stable between sites? What are parametrs that I can verify?
Correct Answer by Jon Marshall about 6 years 8 months ago
marcelo.fanaia wrote:
This time is too much for last time the route was updated. Isn't It? What do you think about?
B     192.168.111.0/24 [20/0] via 10.1.0.2, 06:01:25
B     128.254.216.0/22 [20/0] via 10.1.0.2, 06:01:37
Best Regards
Marcelo
Marcelo
BGP does not send periodic routing updates as other protocols do. So unless the route has changed no update will be sent.
Jon
Overall Rating: 5 (2 ratings)
Reza Sharifi Wed, 09/15/2010 - 18:23
  • Cisco Designated VIP,
    2017 LAN
For OSPF, if you issue "show ip ospf neighbor detail" it will show you how long the neighbor has been up
For BGP issue "sh ip bgp su" this will also tell you how long the neighbor has been up and running
Reza
marcelo.fanaia Wed, 09/15/2010 - 18:32
Best Regards
Marcelo
Correct Answer
Jon Marshall Wed, 09/15/2010 - 18:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Best Regards
Marcelo
Marcelo
Jon
