Integrate Unity 4.2 to (2) Callmanager clusters
nelson.chu
Is it possible to use a single Unity 4.2 for (1) CCM 4.2 and (1) CUCM 7.1 cluster at the same time?  For example, splitting the ports to both clusters. We have a large (>30K) VoIP deployment and need to upgrade the Callmanager cluster and Unity, so this is for migration purpose.
Nelson
David Hailey
Yes, you can do this.  You will need to upgrade the TSP to ensure compatibility with CUCM 7.x and manage two integrations (within UTIM) but it can be done.  Go here:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/cucm_sccp/guide/cuintcucmskinny090.html
From there, look for a link and section titled "Multiple Clusters".
Should get you what you need.
D. Hailey
Please rate helpful posts!
David Hailey
D. Hailey
David,
Thanks!  Is it possible to have (1) Unity 4.2 and (1) Unity Connection 7.1 integrated to (1) CUCM 7.1 cluster at the same time?
Nelson
Rob Huffman
Hi Nelson,
You can integrate both simultaneously
The 2nd integration will need new Ports, VM Profile, Hunt Pilot etc. but you
should be good to go.
Cheers!
Rob
I had a near identical requirements a while ago for a customer migration. I opted to leverage Q.SIG between the two Call Manager clusters for handling the VM integration. I assigned all ports to one cluster and just tunnelled MWI through Q.SIG (via ICT). There are things to be dealt with for sure (like overlapping dial plans) but I found it relatively painless.
I did a quick write up on the experience. Maybe you will find it useful.
http://www.netcraftsmen.net/resources/blogs/using-qsig-to-integrate-unity-with-multiple-cucm-clusters.html
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
