Trend CSC SSM file blocking issue
bus1nesssa
Attempting to use the File Blocking function under Web (HTTP) | File Blocking to block .scr files.
Added 'scr' into Block specified file extensions, and enabled this option .. and the system started to block anything from main.aspx files to google search result pages.
(we had notifications turned on and were swamped with messages within seconds)
Any ideas ?
abinjola
which version of CSC are you running ?
you may want to have a look at : CSCtb9002    CSC: File Blocking - Executables also blocks some CSS and SWF files
--regards
Sorry, forgot to put that in.
v 6.3.1172.0
Unfortunately I can't get to that link and can't find a reference to it on the Cisco site.
May have jumped the gun posting this one as release 6.3.1172.3 may have resolved the issue :
New features in 6.3.1172.3:
   Issue: Users may not be detected on a PC with multiple IP addresses.
   Affects: 6.3.1172.0-6.3.1172.2
   Change: Allowed the client workstation to be queried directly when the log-parsing approach does not work.
Bug-fixes in 6.3.1172.3:
   Issue: The Active Directory agent is unable to query usernames from the Domain Controller.
   Change: Enhanced the Global Catalog (GC) discovery mechanism to bind to the correct GC.
  Issue: Sometimes the Domain Controller Agent cannot find the username/group by IP address.
Will apply it this weekend and check it out.
