How can I telnet to ASA's outside interface?
Sep 15th, 2010
  I want telnet to a asa outside interface.
I know that the asa doesn't allow to telnet to the lowest interface , but the cisco says "If IPsec operates, you can specify an unsecure interface name, which is typically the outside interface. At a minimum, you can configure the crypto map command in order to specify an interface name with the telnet command. "
but,how can i finished this configuration?
Related Content
