tracking and ip sla monitoring
Answered Question
Sep 15th, 2010
Having a syntax issue, not sure about it.
#sh version
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
System image file is "flash0:c2951-universalk9-mz.SPA.150-1.M3.bin"
ip sla monitor 1
brings back 'invalid input'... so "ip sla ?" only gives
"key-chain" and "responder" as options...
Also:
track 1 rtr 1 reachability
brings back 'invalid input'.... "track 1 ?" gives
"interface" "ip" "list" "stub-object"
I'm trying to create an sla monitor for failover.
delay down 15 up 10
ip sla monitor 1
type echo protocol ipIcmpEcho 1.1.1.1 source-interface ethernet0
timeout 1000
threshold 40
frequency 3
ip sla monitor schedule 1 life forever start-time now
Something like that....
It's a brand new 2951.
Any ideas?
Correct Answer by Lei Tian about 6 years 5 months ago
Check the license from your 'show ver' output;  IP SLA requires data license package.You need to buy the data license to active the feature. You can use  the evaluation license to test, but eventually you need the  license to active the feature.
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1097675
Lei Tian
Overall Rating: 5 (1 ratings)
