Migrate standalone 6500 switch to VSS.
Sep 15th, 2010
Hello.
I'm reading some documents about migrating standalone switch
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c74c.shtml
I'm looking for pre-configuration steps that should be performed before converting: channel and loopback renumbering, ...
Many thanks.
Regards.
Andrea
Ruchir Jain Thu, 09/23/2010 - 09:51
  • Cisco Employee,
Hi Andrea,
When you convert a switch into VSS the switch itself will renumber the physical interfaces from 2 level format to 3 level format. Since we have two switches in VSS so switch number 1 would have its interface renumbered to number 1/x/x from x/x and simillarly switch 2 would have iterfaces renumbered from x/x to 2/x/x. Loopback numbers would remain the same as well as the port-channel.
Though you would need to create two new port-channels which would be used for the VSL link.
I am not sure how much this was of use to you but if you could describe your concerns in detail may be I could help better.
Also, I have this command reference that I made myself for VSS. I will attach it. May you would find it useful.
Cheers,
Ruchir
christian_jorge Fri, 01/16/2015 - 17:16
Hello
I will perform a migration of 2 switches to a VSS.
My specific concern is about same etherchannels presented in both switches.
For example, in primary switch we have port-channel 10 connecting server A and secondary switch we have the same channel id (port-channel 10) connecting another server (server B).
Do we have to change one channel id before migration?
We are worried about having 2 servers in same channel due to a wrong convertion. Is it possible or will switches have an "intelligence" to avoid this?
Christian
andrea.meconi@c... Tue, 01/20/2015 - 02:12
Hello Christian.
Yes, you need to change one ID.
When VSS is enabled, two switches work like one, so you cannot have two channels with the same ID.
Regards.
Andrea
