7921 Roaming Problems
Sep 16th, 2010
I'm having Roaming-Problems with 7925 Wireless Phones. The 7925 in some cases lose their connection during Layer 3 Roaming to another controller.
My Setup:
- 7921 Wireless Phones
- 2 WiSMs (4 4402 Controllers)
- WCS
- 1142 Access-Points
- 1 Mobility Group
-  Multiple AP-Groups using different Subnets
- L3 Roaming using Symetric Tunneling
- DHCP
To fix the problem I manually removed the client association, which deletes the mobility anchor too. The telefphone gets a new IP-Adress in the current AP-Group.
Any ideas?
andreas.eichhor... Thu, 09/16/2010 - 04:00
if you are using 6.0.199.0 you should upgrade to 6.0.199.4 because there is a bug in the 6.0.199.0 software which is making problems with roaming.
