Showing results forĀ
Search instead forĀ
Did you mean:Ā
UCCX Process DIsable
antonio.fragoso
Hi Everebody
I am installing the  Unified CCX - but I am CRS Administration an CRS Engine Process are always going to DISABLE mode. Does any body now how can I fix this issue
Other question concerning the  "CRS Admin Utily" - What is the user name and password ?
Walter Solano
Level 7
Level 7
In order toi know why the engine is going into partial service you will need to check the MCVD trace, those are in C:\Program Files\Wfavvid\Log
MCVD
154551808
Hi Antonio,
What is the version of UCCX???
Best regards.
Mauricio
Hi Mauricio
I using the
Version5.0(2)_Build064
I am puting some MCDV trace log
