DFM Install Questions
nawas
Level 4
Level 4
I didn't install DFM when I installed LMS 3.0 on my Solaris10 and after installing 3.0 I upgraded to LMS3.2. Now I feel I have a need to install DFM but I'm not sure how do I go about installing DFM. Please advise.
I currently have following modules/versions installed
LMS3.2
Campus Manager 5.2.1
CiscoView 6.1.9
CiscoWorks Assistant 1.2.0
CiscoWorks Common Services 3.3.0
Integration Utility 1.9.0
Internetwork Performance Monitor 4.2.0
LMS Portal 1.2.0
Resource Manager Essentials 4.3.1
11 Replies 11
Joe Clarke
Just install DFM 3.2 from the LMS 3.2 distribution.  You do not need to worry about upgrading.
LMS 3.2 distribution? You mean I should use the DVD to install DFM? I have LMS3.0 DVD and 3.2 upgrade I installed from the web.
If you downloaded LMS 3.2, then use the downloaded image to install DFM 3.2.
Can't seem to find the link, can you point me to a link to download?
I had assumed you already had the image downloaded.  LMS 3.2 was removed from the eval download site after LMS 4.0 was published.  It is being put back, but that will take some time.  Check http://www.cisco.com/go/lms later today.
I had installed LMS3.2 sometime last year and couldn't seem to find the donwload copy on my PC.I will wait till it show up on the URL you mentioned.
Now that LMS4.0 is out, can I simply donwload/install LMS4.0 directly and choose DFM install or do I have to go to LMS3.2 >install DFM> and upgrade LMS4.0. IS LMS 4.0 a free upgrade?
Thank you.
LMS 4.0 is not a free upgrade from 3.2.  You can download and install 4.0, but you will need to first uninstall 3.2.  There is no inline upgrade.  You can, however, restore your 3.2 backup into 4.0 for purposes of data migration.
I still couldn't find the LMS3.2 download on the url you mentioned. I found another link  (you posted for somone else) but it had the LMS 3.2 for windows. I have a TAC case open if I provide SR number, can you give engineer the link to download or may be provide special file access?
The link for both Solaris and Windows downloads of LMS 3.2 is https://cisco.mediuscorp.com/market/networkers/homeWork.se.work;jsessionid=7030b9cb2cd2O$DA$12M .
I think it is a broken link but i saw lms 3.2 on this link, once i clicked "add to cart" it came with an empty page, i tried again and it took me to the page where i was earlier and that had Cisco NAC eval and LMS 3.2 windows version but no solaris version.
Use http://www.cisco.com/go/nmsevals .  I was able to download the Solaris download manager stub from that link.
