ACS 5.2 Not contacting RSA server for Authentication
Sep 16th, 2010
Hey all,
I have a new stand-alone ACS 5.2 install, and have setup an RSA Server under "RSA SecureID Token Servers", and have imported the sdconf file.
On the RSA side, I've added the ACS server to the Agent hosts, per RSA instructions, and was sure to create the sdconf file AFTER adding the agent host.
It seems like the ACS isn't attempting to contact the RSA at all to authenticate, and I can't figure it out.
I've setup Identity Store Sequences, and have chosen my RSA server as the sole password authentication method.
I hope I can find some help here, if you guys need more info, I'll be happy to supply it.
Thanks!
davebornack Thu, 09/16/2010 - 07:12
Also, this is the error I'm getting in the TACACS+ Logs..
22056 Subject not found in the applicable identity store(s).
