COBRAS
Sep 16th, 2010
Hello Folks,
I am trying to Activate and Strat the "Connection Database Proxy" in order to use COBRAS but the service doesn't start. It stays in the "Service in transition" mode for while and stops right after. I am using the "cmadmin" username and password but it looks like this is not the problem.
MK
Overall Rating: 5 (2 ratings)
Rob Huffman Thu, 09/16/2010 - 07:41
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi MK,
Hope all is well buddy
Can you try setting this as a "first" step;
To Change the Database Proxy Service Shutdown Timer
Step 1 In Cisco Unity Connection Administration, click System Settings > Advanced > Connection Administration.
Step 2 In the Database Proxy: Service Shutdown Timer  field, enter a value between 1 and 999 days.
A value of zero disables the Database Proxy Service.
Step 3 Click Save.
Cheers!
Huff
mightyking Thu, 09/16/2010 - 07:59
Thanks Rob, it's working now. Do I need to start this service in the Sub as well? Do I need to put the time back to 0 when I am done with the backup? Do I need to shutdown the Sub while importing the data to the Pub?
MK
Rob Huffman Thu, 09/16/2010 - 08:50
  • Hall of Fame,
    Founding Member
Hi MK<
Good stuff
1. only needs to be started on Pub
2.the Database Proxy service will shut down automagically after the days specified
3. you shouldn't need to shut down the Sub
Cheers!
Rob
