XENPAK-10GB-LR with Cisco 6509-no signal
Sep 16th, 2010
Hi Experts
I have cisco 6509 with the following modules.The issue i am facing is that the LR optics are not lighting up.As per the software advisor i tried the following software images.The SR modules within the same chassis works.The issue is there with my other switches like cisco 4900M,Cisco 3750-E all of which have the LR modules and they dont lit up whereas the SR does.Kindly help me out.
rgds
ashwin
s72033-ipservicesk9-wan-mz.12.2.-33.SXI3
s72033-ipservicesk9-wan-mz.12.2.-33.SXh6
s72033-ipservicesk9-wan-mz.12.2.-33.SXf16
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  3    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  4    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  6    2  Supervisor Engine 720 (Cold)           WS-SUP720-3B
  1  Centralized Forwarding Card WS-F6700-CFC       SAL13516UNL  4.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL13516K6T  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL13516US2  4.1    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL13516MGM  4.1    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1350604W  2.6    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL135067FL  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       SAL135068FE  2.6    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL1350639R  4.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
Overall Rating: 5 (7 ratings)
ariyer2003 Thu, 09/16/2010 - 08:25
I am aware that LR works with single mode.The question is shoudnt i be seeing some red laser inside the optic as soon as it is inserted into the line card??
rgds
ashwin
Jerry Ye Thu, 09/16/2010 - 08:32
  • Cisco Employee,
I suggest you not to look at it. This is a powerful laser and it can damage your eye. Also, the wave length is very small (1310nm), you might not able to see if if you decide to look at it. The best way to do it is to use an optical power meter to check if there is any power coming out from the XENPAK.
jerry
francisco_1 Thu, 09/16/2010 - 08:44
  • Gold, 750 points or more
doesnt look like your IOS is support for this transceiver!!!
Table 6 Catalyst 6XXX Switch Support and Minimum Software Release Requirements
Platform
Switch or Module
Transceiver Model
Minimum Software Release Required
Catalyst Operating System
Cisco IOS
DOM Support
Catalyst 6500 series
WS-X6704-10GE
WS-SUP32-10GE-3B
XENPAK-10GB-LR
XENPAK-10GB-LR+
XENPAK-10GB-LW
XENPAK-10GB-ER
XENPAK-10GB-ER+
XENPAK-10GB-LX4
XENPAK-10GB-SR
XENPAK-10GB-CX4
XENPAK-10GB-ZR
XENPAK-10GB-LRM
DWDM XENPAK
8.1(2)
8.1(2)
8.4(4)
8.2(1)
8.2(1)
8.2(1)
8.3(1)
8.3(1)
8.5(1)
8.6
8.5(1)
12.2(17a)SX
12.2(17a)SX
12.2(18)SXE
12.2(17a)SX
12.2(17a)SX
12.2(17a)SX1
12.2(17a)SX1
12.2(17a)SXB1
12.2(18)SXF
12.2(18)SXF11
12.2(18)SXF
12.2(18)SXE
12.2(18)SXE
12.2(18)SXE
12.2(18)SXF
12.2(18)SXF11
12.2(18)SXF
francisco_1 Thu, 09/16/2010 - 08:47
you have a newer code and i dont think the table is up-to-date!!!
Francisco.
Jerry Ye Thu, 09/16/2010 - 08:50
  • Cisco Employee,
The table said Minimum Software Release Required. Any IOS above that in the same train, SX, will support that module.
Jerry Ye Thu, 09/16/2010 - 08:58
  • Cisco Employee,
Your IOS
s72033-ipservicesk9-wan-mz.12.2.-33.SXH6
s72033-ipservicesk9-wan-mz.12.2.-33.SXF16
are fine.
ariyer2003 Thu, 09/16/2010 - 09:13
but still same issue
Jerry Ye Thu, 09/16/2010 - 10:24
  • Cisco Employee,
What is the issue? The remote end, XENPAK-10GB-LR (or any 10G-LR) with SMF, is not detecting the link or you are still trying to look at the light?
faiz10008 Thu, 09/16/2010 - 10:43
Hi Jeye,
the issue is the 6509  XENPAK-10GB-LR - link is not coming up while connecting to 4900 cisco XENPAK-10GB-LR in which is located in one of the HUB-Rooms
Jerry Ye Thu, 09/16/2010 - 11:09
  • Cisco Employee,
Just for a quick L1 test, you can use a single strand SMF and connect the same XENPAK TX and RX together to check if it is working or not. The good XENPAK should give you a green light if you look at the front when connecting the TX and RX together.
marikakis Thu, 09/16/2010 - 12:10
I would follow Jerry's advice and not try to look at the light.
Jerry, does the loopback test you proposed require the use of an attenuator? I think I see that in the asterisks of Table 1 in the document included in your first post.
marikakis Thu, 09/16/2010 - 13:10
Hi Jerry,
Looks like my eye got confused with the number of asterisks. I guess me trying to look at the light wouldn't have been more successful, even if it wasn't dangerous.
Maria
Jerry Ye Thu, 09/16/2010 - 08:48
  • Cisco Employee,
Once again, I will not look at it and it is your choice to look at it. Hence, I will not confirm if you can see it or not. I will use optical power meter to check the power of the XENPAK.
Also, 12.2(33)SRA is for 7600's, the module is detected with your IOS software and it should be fine. The WS-X6704-10GE is supported since IOS 12.2(17a)SX or CatOS 8.1.2.
jerry
