EIGRP ASA 5510 and 1841 ISR
Answered Question
Sep 16th, 2010
Greetings.
Our network setup looks like this:
ASA 5510 --->> E0/1 (1841 ISR) E0/0 --->> Catalyst Switch
We've recently added an ASA 5510 to the network to replace the old hardware firewall. We have multiple VLANs setup on E0/0 of the 1841. I've attempted to configure EIGRP on the ASA and the ISR so that they would share the routing information between themselves but it didn't work. When I checked for neighbours, none were discovered/
Is it possible to do EIGRP this way?
Correct Answer by Jon Marshall about 6 years 7 months ago
So 192.168.15.x is the network connecting the ASA to the router ?
Is there any reason you have auto-summary on ? if not can you turn it off on both devices eg.
router eigrp
no auto-summary
also have you tried to debug eigrp on the router to see what it thinks is happening ?
Jon
Can you also confirm your ASA is not -
1) running in multiple context mode
2) running in transparent mode
Jon
Overall Rating: 4.3 (3 ratings)
Jon Marshall Thu, 09/16/2010 - 08:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you post EIGRP config for firewall and router ?
Jon
Felix Bowman Thu, 09/16/2010 - 08:48
Here are the configuration lines:-
ASA
router eigrp 1
network 192.168.15.0 255.255.255.0
redistribute static
ISR
router eigrp 1
redistribute static
network 192.168.5.0
network 192.168.13.0
network 192.168.14.0
network 192.168.16.0
network 192.168.17.0
network 192.168.18.0
network 192.168.19.0
network 192.168.22.0
network 192.168.23.0
network 192.168.24.0
network 192.168.26.0
network 192.168.27.0
auto-summary
Correct Answer
Jon Marshall Thu, 09/16/2010 - 08:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
router eigrp
no auto-summary
Jon
Felix Bowman Thu, 09/16/2010 - 09:05
This seemed to be it. The routes have showed up.
Thank you both for taking the time out to look at and respond to my question. I appreciate it very much.
Correct Answer
Jon Marshall Thu, 09/16/2010 - 08:50
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
Felix Bowman Thu, 09/16/2010 - 08:57
The ASA is running in routed mode and single context mode.
