Need to disable viewmail so voicemails aren't delivered to Outlook
gonzalezel
We are running Unity 5.x with Unified Messaging. Is there anyway to disable the feature that delivers the voicemail to Exchange/Outlook I was able to remove the Viewmail software but I am still receiving the voicemails in my inbox at .wav files.
anmcbrid
With unified messaging your voicemails are stored in your exchange inbox.  Not much you can do about that other then create another AD account for yourself with a different mailbox for just voicemail.
Unity Connection doesn't require that setup.
