OSPF Routes are in the OSPF Database but not in the Routing Table
Answered Question
Sep 16th, 2010
Dear Members,
i have a problem with redistributing OSPF routes in my MPLS VPN. My local routes are redistributed into the MPLS VPN which is running BGP. This is the configuration of the edge router.
hostname CU_EDGE01
ip vrf CU_A
rd 100:26
route-target export 100:26
route-target import 100:26
interface Loopback0
ip address 1.1.1.252 255.255.255.255
ip router isis
interface FastEthernet0/0
description LINK TO Customer Router 01 FA0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.26
encapsulation dot1Q 26
ip vrf forwarding CU_A
ip address 172.16.2.5 255.255.255.252
interface FastEthernet0/1
description LINK TO P_ROUTER_FA0/0
ip address 1.1.1.2 255.255.255.252
ip router isis
speed 100
full-duplex
mpls ip
router ospf 100 vrf CU_A
log-adjacency-changes
redistribute bgp 100 metric 20 subnets
network 172.16.2.4 0.0.0.3 area 0
router isis
net 41.0000.0000.0004.00
is-type level-1
router bgp 100
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 1.1.1.251 remote-as 100
neighbor 1.1.1.251 update-source Loopback0
address-family ipv4
neighbor 1.1.1.251 activate
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 1.1.1.251 send-community both
exit-address-family
address-family ipv4 vrf CU_A
redistribute ospf 100 vrf CU_A match internal external 1 external 2
no synchronization
exit-address-family
the routes are redistributed in the BGP process as desired. See the output.
CU_EDGE01#show ip bgp vpnv4 all
BGP table version is 9, local router ID is 1.1.1.252
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 100:26 (default for vrf CU_A)
*>i10.2.2.0/24      1.1.1.251               11    100      0 ?
*> 10.3.0.1/32      172.16.2.6               2         32768 ?
*> 172.16.2.4/30    0.0.0.0                  0         32768 ?
*>i172.16.20.4/30   1.1.1.251                0    100      0 ?
CU_EDGE01#
Also in the OSPF Database i can see the routes.
CU_EDGE01#show ip ospf database
            OSPF Router with ID (172.16.2.5) (Process ID 100)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
172.16.2.5      172.16.2.5      30          0x80000002 0x007AA4 1
172.16.2.6      172.16.2.6      31          0x80000002 0x0072AB 1
                Net Link States (Area 0)
172.16.2.6      172.16.2.6      31          0x80000001 0x000526
                Summary Net Link States (Area 0)
10.2.2.0        172.16.2.5      17          0x80000001 0x005B7B
10.3.0.1        172.16.2.6      66          0x80000001 0x001E4B
172.16.20.4     172.16.2.5      17          0x80000001 0x006FA3
The route from the far end is the 10.2.2.0/24. The down bit is also set.
CU_EDGE01#show ip ospf database summary 10.2.2.0
  LS age: 134
  Options: (No TOS-capability, DC, Downward)
  LS Type: Summary Links(Network)
  Link State ID: 10.2.2.0 (summary Network Number)
  Advertising Router: 172.16.2.5
  LS Seq Number: 80000001
  Checksum: 0x5B7B
  Length: 28
  Network Mask: /24
        TOS: 0  Metric: 20
in the routing table of the vrf CU_A i see the routes. My qestion here is, why the route to 10.2.20/24 is a BGP route and not a OSPF route?
CU_EDGE01#show ip route vrf CU_A
Routing Table: CU_A
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     172.16.0.0/30 is subnetted, 2 subnets
B       172.16.20.4 [200/0] via 1.1.1.251, 00:02:57
C       172.16.2.4 is directly connected, FastEthernet0/0.26
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O IA    10.3.0.1/32 [110/2] via 172.16.2.6, 00:03:05, FastEthernet0/0.26
B       10.2.2.0/24 [200/11] via 1.1.1.251, 00:02:57
CU_EDGE01#
on the local router the routes are also in the OSPF Database
CU_RT1#show ip ospf database
            OSPF Router with ID (172.16.2.6) (Process ID 100)
172.16.2.5      172.16.2.5      258         0x80000002 0x007AA4 1
172.16.2.6      172.16.2.6      258         0x80000002 0x0072AB 1
172.16.2.6      172.16.2.6      258         0x80000001 0x000526
10.2.2.0        172.16.2.5      245         0x80000001 0x005B7B
10.3.0.1        172.16.2.6      293         0x80000001 0x001E4B
172.16.20.4     172.16.2.5      245         0x80000001 0x006FA3
                Router Link States (Area 10)
172.16.2.6      172.16.2.6      298         0x80000001 0x00C9CF 1
                Summary Net Link States (Area 10)
172.16.2.4      172.16.2.6      301         0x80000001 0x00F8BE
                Summary ASB Link States (Area 10)
172.16.2.5      172.16.2.6      261         0x80000001 0x00F2BF
CU_RT1#
but on the routing table for the vrf CU_A i cannot see the route to 10.2.2.0/24
CU_RT1#show ip route vrf CU_A
Routing Table: CU_A
     172.16.0.0/30 is subnetted, 1 subnets
     10.0.0.0/16 is subnetted, 1 subnets
C       10.3.0.0 is directly connected, Loopback103
CU_RT1#
Does anybody has an explaination for the missing OSPF routes?
Thank you very much in advanced
Alex
Correct Answer by Lei Tian about 6 years 8 months ago
Hi Alex,
The prefix with down bit set will not be put in RIB. This is done by default to prevent loop. Did you have 'capability vrf-lite' configured on CE? You need this command on CE to receive a LSA with down bit, when using multi-vrf.
http://www.cisco.com/en/US/docs/ios/12_0st/12_0st21/feature/guide/ospfvrfl.html#wp1039220
HTH,
Lei Tian
Overall Rating: 5 (1 ratings)
Correct Answer
Lei Tian Thu, 09/16/2010 - 14:33
  • Cisco Employee,
Hi Alex,
HTH,
Lei Tian
