How can i create MAC base ACL in cisco router 2800 &1800
Sep 16th, 2010
hi,
I want to create mac base ACl for all  users and laptop . So that I can restrict unauthorized user or laptop. MY current scenario is like :---
wireless user/Laptop ------> Access point------->Poe switch (L2)-------> WLC (wireless LAN controller )-------->Radius server ------------>AD------------> LAN
In above scenario unauthorized user can access Internet or can get some access through static IP. So i am planning to implement following because i have Cisco 2800 and Cisco 1800 router  and also due lack of budget.
wireless user/Laptop ------> Access point------->PoE switch (L2)------->Cisco router (with MAC base ACL)--------> WLC-------->Radius server ------------>AD------------> LAN
Please suggest me to resolve this issue.
Thanks & Regards,
Sujeet
Overall Rating: 5 (2 ratings)
sujitkr7cisco Sat, 09/25/2010 - 11:34
Sorry for late reply.
I am not able to access link , which is send by you.
Please send me another link.
gatlin007 Sat, 09/25/2010 - 13:40
  • Silver, 250 points or more
This may be hardware/feature set/IOS dependant.
access-list (standard-ibm)
To establish a MAC address access list, use the access-list command in global configuration mode. To remove access list, use the no form of this command.
access-list access-list-number {permit | deny} address mask
no access-list access-list-number
Syntax Description
access-list-number
Integer from 700 to 799 that you select for the list.
permit
Permits the frame.
deny
Denies the frame.
address mask
48-bit MAC addresses written as a dotted triple of four-digit hexadecimal numbers. The ones bits in the mask argument are the bits to be ignored in address.
Defaults
No MAC address access lists are established.
Command Modes
Global configuration
Command History
Release
Modification
10.0
This command was introduced.
12.2(33)SRA
This command was integrated into Cisco IOS Release 12.2(33)SRA.
12.2SX
This command is supported in the Cisco IOS Release 12.2SX train. Support in a specific 12.2SX release of this train depends on your feature set, platform, and platform hardware.
Usage Guidelines
Configuring bridging access lists of type 700 may cause a momentary interruption of traffic flow.
Examples
The following example assumes that you want to disallow the bridging of  Ethernet packets of all Sun workstations on Ethernet interface 1.  Software assumes that all such hosts have Ethernet addresses with the  vendor code 0800.2000.0000. The first line of the access list denies  access to all Sun workstations, and the second line permits everything  else. You then assign the access list to the input side of Ethernet  interface 1.
access-list 700 deny 0800.2000.0000 0000.00FF.FFFF
access-list 700 permit 0000.0000.0000 FFFF.FFFF.FFFF
interface ethernet 1
 bridge-group 1 input-address-list 700
Related Commands
Command
Description
access-list (type-code-ibm)
Builds type-code access lists.
