AP's cannot join controller while it is restarted
Sep 16th, 2010
Hi ,
I'm using WLC 2106 and 1130 AP's
They're working perfectly, but when I restart the WLC ( while AP's are on, because they have their on power supply ), they cannot join the controller afterwards
Then i need to manualy restart also AP's and after that they join controller.
It's strange because they all have their own static ip addreses , and the MGMT interface address of the WLC is on the same subnet
So is there aby solution ?
It's not easy to restart AP's all the time somewhere on the ceiling ; )
thanks
pet
Overall Rating: 5 (1 ratings)
peter_jevos Thu, 09/16/2010 - 15:32
thank you for your answer
WLC: Software Version                 5.2.193.0
AP-s IOS: 12.4(18a)JA2
Leo Laohoo Sun, 09/19/2010 - 02:12
Cisco's been recommending everyone to stay away from the 5.X and 6.X codes.  Please upgrade to the 7.X code.
