EIGRP vs Multilink for Load Balancing
Answered Question
Sep 16th, 2010
I'm planning on implement a solution of VoIP over a 2 parallel WAN links.
Because the bandwidth on both links is less than 512kbps, its important to load balance the traffic between both.
EIGRP its implemented over all the network, so i have the option to use variance to load balance between this links (512kbps and 384kbps)
My second option is tu join both link with MULTILINK.
I want to know which of this options is recomended considering that Data and VoIP will go trought this conection.
Anothe consideration is that i need to implement QoS.
Osvaldo U.
Correct Answer by Giuseppe Larosa about 6 years 9 months ago
Hello Osvaldo,
PPP multilink can give you the capability to perform interleaving to minimize VOIP packets delay and jitter.
So given the low speeds of links would be wise to use PPP multilink.
However, the speeds are different (512 Kbps and 384 kbps) and MLPP cannot handle this. So in this case I would use EIGRP with variance and each interface needs its own QoS settings to provide better treatment to VOIP packet. ( Low Latency Queueing).
The use of Policy Based Routing (PBR) to divert all VOIP traffic to a single link can be considered also.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Sun, 09/19/2010 - 13:04
  • Hall of Fame,
    Founding Member
Hello Osvaldo,
Hope to help
Giuseppe
