Anyconnect with SBL not working
Sep 16th, 2010
I am trying to get the SBL to work for Windows XP/Vista/7 using an ASA5510 running 8.2 (1). When I login to the WebVPN, it installs the anyconnect client and SBL components,  and copies the xml profile. When I reboot, I get nothing popping up (on an XP machine) before login...any ideas? I have included below my config for the webvpn...I also worked with TAC and they could not find the problem either. Any help you can give me is appreciated.
webvpn
enable outside
svc image disk0:/anyconnect-win-2.5.0217-k9.pkg 1
svc profiles profile1 disk0:/AnyConnect.xml
svc enable
group-policy WebVPNPolicy internal
group-policy WebVPNPolicy attributes
wins-server value 192.168.2.10 192.168.2.13
dns-server value 192.168.2.10 192.168.2.13
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value WebVPNACL
webvpn
  svc modules value vpngina
  svc profiles value profile1
slawford Sun, 09/19/2010 - 23:37
  • Cisco Employee,
Could you please confirm:
Steve.
bchewning Mon, 09/20/2010 - 08:21
Thanks for the reply! I actually did not change anything and it is working this morning. This leads me to believe it was a PC issue. Thanks for the reply!
