09-16-2010 03:38 PM - edited 07-03-2021 07:11 PM
iPhone 4 cannot connect to my Aironet 1141 AP if WPAv2 Personal is used. If I use no security or WPAv1 the iPhone connects perfectly.
I really would like to connect using WPAv2. Anyone know what I should do to fix it?
Rgds.
Stan Chelchowski
Solved! Go to Solution.
10-08-2010 04:31 AM
Is this Autonomous AP? Not sure what cipher you are using with WPA2 but try AES with WPA2.
keep us posted
Thx
Serge
10-08-2010 04:31 AM
keep us posted
Thx
Serge
10-08-2010 05:28 AM
Hi Serge, Thanks for replying.
Yes, it is Autonomous and running in a small office with a simple environment. I have it set to TKIP, I'll try AES and see if that succeeds.
I'll post the result.
Rgds.
Stan Chelchowski
10-09-2010 12:06 AM
Hi Serge,
Bingo! You nailed it !
Set to AES not TKIP...
Thanks.
Rgds.
Stan Chelchowski
