09-16-2010 04:16 PM - edited 03-16-2019 12:49 AM
Does anyone have instructions on how to convert a .wav or mp3 file to the proper .raw format using CoolEdit? Other posts here recommend using Cool Edit and I know the file requirements for the file format. I just cannot seem to get it right becuase the converted files are mostly played as static with the sound faintly in the background. I have spent WAY too much time trying to get what I thought would be a simple task to work!
(CUCM 7.x, 7945 phone with SCCP45.8-5-3S)
Thanks in advanced!
09-16-2010 11:40 PM
Hi There,
Have you tried using Cisco Phone Designer? You can push mp3's to your phone for use as ringtones
HTH, If so please rate
Justin
09-17-2010 10:47 AM
Justin:
This worked out for me. Although I am using two applications to create a single ringtone, the Phone Designer application did convert the file to the proper format with no issues in the playback. I still am using Cool Edit to fade-in/out and saving a segment of the entire file to the required 20 seconds. In this situation, we did not want to allow end users this capability, and it was not feasible to connect to 1000+ phones to change.
For the sake of others who may read the post, here's what I had to do:
