AnyConnect for Mac/Where are User Specific Files?
Sep 16th, 2010
Greetings,
AnyConnect for Mac is crashing for one specific user on my system.  Any other users I create can log in just fine using AnyConnect.
I am trying to find out where all user specific files are as it relates to AnyConnect and the user starting the client.  I am hoping to identify them so I can either repair or remove them with the hope that it will resolve my issue.
Best regards,
Brenden
Atri Basu Fri, 09/17/2010 - 01:05
Hey Brendan,
If you are using CSD, then you'll find information regarding the log files at this link:
http://www.cisco.com/en/US/docs/security/csd/csd35/configuration/guide/CSDglobe.html#wp1208960
If you looking only for client files then on a MAC they are located in /Applications/Cisco AnyConnect VPN Client/Contents/Resources.
However particularly for crashes you can follow the following steps:
  1. Open the /Applications/Utility folder and launch the "Console" application.
  2. Select the "Show Log List" option.
  3. Navigate to "LOG FILES -> ~/Library/Logs -> CrashReporter"
  4. Look for any "Cisco Anyconnect" or "vpnagentd" logs ie:
     ~/Library/Logs/CrashReporter/Cisco AnyConnect VPN Client.crash.log
Hope that helps.
Atri.
