RTMT displays LowActivePartitionAvailableDiskSpace alert,
Answered Question
Sep 16th, 2010
RTMT displays an "LowActivePartitionAvailableDiskSpace alert, which indicates there is a low disk space on active partition
CCM Vertion - 5.1.2
Disk /active free space available - 510388k
Pls advice,
Tnx,
Asanka
Correct Answer by malnaima about 6 years 10 months ago
Hello Asanka,
Can you kindly update us if you are using CAR/CDR ?
As this can be a well known issue here where in CUCM 5.1.2 scheduled CAR reports are written to the active partition and Having most or all scheduled CAR reports enabled and archived for as long as possible may consume all available disk space on the active partition.
What you can do for the timebeing is stop CDR/CAR if not used or purge CDR records to clear disk space other wise if the consumption increases you will need to open a TAC case so that a TAC engineer can apply a workaround for you.
Best Regards,
Mahmoud
Overall Rating: 5 (1 ratings)
Justin Brenton Thu, 09/16/2010 - 23:22
  • Silver, 250 points or more
Hi there,
This is normal with the operation of the server. The recommendation to resolve this issue is to change the alert threshold in RTMT to be at 2% or 3% so that you stop receiving unnecessary warnings.
To do this:
Open RTMT >  Open the tools tab at the bottom left of the screen, and select
'Alert  Central'.  Find the "LowActivePartitionAvailableDiskspace' parameter,  right-click on it and go to properties. Click next and on the next
screen you can set the threshold to 3%. Click next two more times, then
activate.
https://supportforums.cisco.com/message/1093739#1093739
HTH, please rate if so
Justin
Correct Answer
malnaima Fri, 09/17/2010 - 02:39
  • Cisco Employee,
Hello Asanka,
Best Regards,
Mahmoud
askodikara Tue, 09/21/2010 - 01:40
Hi All
First I would like to apologize for the delay in my reply.
Yes,  Im going to open a TAC case to clear the disk space
Thanks for the support
Asanka
Related Content
