Netflow report with ifName?
Sep 16th, 2010
Need some help on Netflow reporting...
I am using Cisco Netflow Collector version 6.0 and it is collecting Netflow data correctly.
Question is which report (aggregation schemes) will give me flow data with the router's interface name? I tried using the "key builders" in the collector but fail....
Any suggestion will be really appreciated....
Thanks..
Giuseppe Larosa Fri, 09/17/2010 - 00:46
  • Hall of Fame,
    Founding Member
Hello Chowvy,
as far as I know all netflow export packets contain the SNMP ifindex of the interface and not the name.
you can easily check the corrispondence of SNMP ifindex and interface name using the following command
show snmp mib ifmib ifindex
you can take the output of the show in a text file and you can write a script that puts the interface name in place of SNMP ifindex.
it is also recommended to configure snmp if-index persist so that SNMP ifindexes are kept the same across device reloads ( note this is not guaranteed in case of IOS upgrade when moving between trains / feature sets)
Hope to help
Giuseppe
choywy Sun, 09/19/2010 - 16:23
Hi guislar,
thanks for your info....Hmm..Is it possible resolve the ifindex via the collector to the ifName and presented in the flow reports?
We've hunderds of devices hence it is a major task for us to write a script and match ifindex to ifName on those devices. Not to mention when there is a IOS upgrade and we have to re-write the mapping again..
Can we ask the collector to snmp poll the devices and resolve it and present it in the flow report?
Thanks..
Giuseppe Larosa Sun, 09/19/2010 - 23:56
  • Hall of Fame,
    Founding Member
Hello Chowvy,
you can have an SNMP query performed on the same server where NFC is running.
However, if you are using Cisco netflow collector  there is a text configuration file that provides the mapping:
nfcifname.xml
/opt/CSCOnfc/config
SNMP interface name mapping configuration file
see
http://www.cisco.com/en/US/docs/net_mgmt/netflow_collection_engine/6.0/tier_one/installation/guide/config.html#wp1057224
you may have a script that executes appropriate SNMP queries on network devices and then populates the above configuration file.
>> NetFlow Collector caches the SNMP query results in memory. You can...changes are made in the nfcifname.xml file, you must restart NetFlow Collector for these changes...
see
www.cisco.com/en/US/docs/net_mgmt/netflow_collection_engine/6.0/tier_one...
Hope to help
Giuseppe
jakewilson Tue, 09/21/2010 - 05:40
Exporting interface names in NetFlow was introduced in IOS 12.4(2)T or 12.4(4)T depending on what Cisco documentation you reference and is supported in NetFlow v9.
Router(config)# ip flow-export interface-names
Interface Names via NetFlow v9 look like this:
The above can also be used with NetFlow NBAR:
Router(config)# ip flow-export template options nbar
Scrutinizer v8 (currently in beta) leverages the above so that administrators have no dependency on SNMP.  You can read more about this by searching the plixer blog.
I hope this helps.
