How to block yahoo messanger on LAN using ASA 5510 ?
abinjola Fri, 09/17/2010 - 02:31
Keep in mind the following:
a) if your messengers are getting tunneled or encapsulated over port 443 then there is no way to block it, inspect IM only deals with native msn/yahoo msngr packets but if its encap'd over http than inspect http will be used
b)Inspect IM supports MSN Messenger 7.0 (Build 7.0.0816), Yahoo Messenger
This was tested by one of our colleague Kureli, and it worked for MSN
Try this for MSN:
regex msn-messenger "^VER [1-9] MSNP[1-9]+.*\x0d\x0a.*MSNMSGR.*\x0d\x0a"
class-map type inspect http match-all http-msn
match request method post
match request body regex msn-messenger
policy-map type inspect http http-msn
class http-msn      reset log
policy-map global_policy
class inspection_default
Note that there is a space between VER and [1-9], and [1-9] and MSNP
