ACE: two URLs, cookie stickyness
Sep 17th, 2010
Hello Experts,
I have a couple of ACE that load balances two web servers using stickyness with cookie insert (BTW the topology is one armed mode). You can see the sanitized config below:
rserver host WEBSERVER1
  ip address
rserver host WEBSERVER2
  ip address
serverfarm host MY-SF
  rserver WEBSERVER1
  rserver WEBSERVER2
sticky http-cookie MY-COOKIE MY-SF-STICKY
  cookie insert
  replicate sticky
  serverfarm MY-SF
class-map match-all WEB-VIP
  2 match virtual-address tcp eq www
policy-map type loadbalance http first-match WEB-POLICY
  class class-default
    sticky-serverfarm MY-SF-STICKY
policy-map multi-match VIPS
  class WEB-VIP
    loadbalance vip inservice
    loadbalance policy WEB-POLICY
    loadbalance vip icmp-reply active
    nat dynamic 10 vlan 222
interface vlan 222
  ip address
  peer ip address
  access-group input IP-ICMP-ANY
  nat-pool 10 netmask pat
  service-policy input VIPS
  no shutdown
The web application asks the Client to connect to two different URLs, for example and
For each URL the Client receives correctly a cookie. How can we force the ACE to send for each of the two URLs a cookie that sticks to a unique real server ? Shall we change the load balancing policy ?
Thanks a Lot
jlamousn Fri, 09/17/2010 - 08:23
Are both urls resolving to the same vip address.  If so, The ace does not care about the  url when inserting cookies.  Any connections that comes to the same vip address will get  the cookie.  The client will remember the cookie for that url, however, and if the client  connects on a subsequent request to the same vip address but using a different url, more  than likely the client will not provide the cookie that it had learned from the previous  request at the other url, and that will cause the ace to potentially load balance that  request to a new server.  So it will be possible in this scenario for the client to be  stuck to two different servers to the same vip address, one for each url or FQDN.
Joel Lamousnery
TAC Customer Support Engineer
