Jennifer Halim Fri, 09/17/2010 - 02:53
ASA does not support load balance within the same context. ASA load balance multiple context as follows:
Context-A via ASA-1, Context-B via ASA-2
You can't route half traffic for Context-A via ASA-1 and the other half through ASA-2 --> this is not supported.
iotoiotoioto Fri, 09/17/2010 - 03:52
Thank you for reply.
So how about Virtual IP address?
ASA-1 contextA and ASA-2 contextA can have a same Virtual IP using HSRP?
iotoiotoioto Fri, 09/17/2010 - 04:21
Sorry my question is bad because of my English.
I hope Active/Standby.
For exsample, One ASA(ASA-1) has context-A,context-B, other ASA(ASA-2) has context-A,context-B.
Then, ASA-1 context-A has VIP (192.168.1.1:Active), ASA-2 context-A has VIP (192.168.1.1:Standby).
Is above possible?
Jennifer Halim Fri, 09/17/2010 - 04:42
No, that is not supported.
Context-A can't be on both ASA-1 and ASA-2.
You can configure the following:
ASA-1: Context-A, Context-B, Context-C
ASA-2: Context-X, Context-Y
If ASA-2 fails for example, the Context-X and Context-Y will failover to ASA-1, and at this point, ASA-1 will have Context-A, Context-B, Context-C, Context-X and Context-Y
Hope that helps.
Diego Armando C... Fri, 09/17/2010 - 09:24
I think that you must have the same context configured in both ASA.
ASA1  context A  and context B
ASA2  contect A  and context B
In ASA 1 you can Have Context A as Acitive and Context B as standby
In ASA 2 you can have COnext A as stanby and context B as Active
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml#lanbas
Im not sure about your answer Halijenn
iotoiotoioto Tue, 09/21/2010 - 19:30
Thank you, Halijenn, diegocambronero.
You are right, I should use Failover, diegocambronero.
I'll do that.thanks.
And I'm interested in Halijenn say things.
I dont understand it very well.
It's impossible to configure HSRP on multi context, right?
I dont care about I have same context on two ASA.
Just I'd like to know to use HSRP on multi context.
So, did you answer after you already know that?
If I misunderstand, point out me.
Thanks Halijenn.
Jennifer Halim Tue, 09/21/2010 - 19:53
No, you are right... You can not configure virtual IP or HSRP for ASA in multi context mode.
