Conversion of Cisco Aironet series 1231G with RM21A module to Lwapp
Answered Question
Sep 17th, 2010
hey folks,
i was wondering whether we can convert the following combo from ios to lwapp.....
1231G with RM21A radio module works fine in autonomous....
Will it work if the same 1231G with RM21A radio module converted to lwapp?
12.3(8)JA2 is IOS software release version the autnomous mode runs....
gone thru the below link.. but its not convincing..
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgr​ade/guide/lwapnote.html​
balag
Correct Answer by Surendra BG about 6 years 10 months ago
case number i cannot pass it on.. its a internal stuff.. only the customer and i can see it.. to clarify ur doubt.. when i used tool to convert the modular radio module which had both G radio and A-radio.. the conversion went well but the AP kept rebooting.. so we consoled into the Ap and tried archive download,.... after which the AP did not relead at all.. and it joined the WLC as well with some SSC issues..
Surendra
Overall Rating: 5 (1 ratings)
Surendra BG Fri, 09/17/2010 - 04:30
  • Cisco Employee,
yes.. the AP can be converted to LWAPP.. and the method which you can go for is the simplest on earth..
archive download-sw /force-reload /overwrite tftp:///
Surendra
balag1986 Fri, 09/17/2010 - 04:31
Thanks for your response.
do not we need to use any upgrade tool?
did you ever tried this and got successfull?
balag
Surendra BG Fri, 09/17/2010 - 04:34
  • Cisco Employee,
haha archive download... command doesnt require any tool.. just needs the conectivity to the server.. and the tool.. yes it has worked for most of my customers while delaing with TAC cases..
But archive download is the easiest..
Surendra
balag1986 Fri, 09/17/2010 - 04:38
Yes. I agree about the command.
But its not re-commended to use when we are converting a IOS series ap to Lwapp for the first time.
Anyhow thats not my concern..
Asking again, did you ever tried and got succussfully converting a 1231G ( 2.4 Ghz radio ) ap with RM21A radio module inserted to Lwapp...
balag
Surendra BG Fri, 09/17/2010 - 04:45
  • Cisco Employee,
it is recommended.. i do it almost thrice a week on the customer ntwork when ever i handle the TAC case point to this issue.. but only issue is with SSC some times.. nad regarding the Tool.. yes i have worked on it and i was successful
Surendra
balag1986 Fri, 09/17/2010 - 04:49
Ok fine. lets do not bother bout the tool or the command....
even we do converted many ios series aps to lwapp either by that command or tool...
but seems like there is a limitation in converting 1231G ( modular access point ios series with explicit RM21A module inserted ) to lwapp...
so just wanted to confirm...
seems like customer not able to convert it successfully and see ap reboots.. but if that RM21A module was removed.. conversion goes fine and everything goes well....
balag
Surendra BG Fri, 09/17/2010 - 04:57
  • Cisco Employee,
ok.. stepping back.. whats is the IOS image on the AP??
Surendra
balag1986 Fri, 09/17/2010 - 04:58
balag
Surendra BG Fri, 09/17/2010 - 05:03
  • Cisco Employee,
ok.. before upgrading the Radio module was the AP upgraded to the new software or after inserting the radio module??
Surendra
balag1986 Fri, 09/17/2010 - 05:07
Customer is using 1231G ( 2.4 ghz ) single radio ap in autonomous mode and it's running well without any issues....
Customer has then inserted RM21A ( 802.11 a) radio module into the card bus of the ap and made 1231G as daul radio ap ( 2.4ghz and 5.0 ghz )... everything done in autonomous mode.. it's running well with no issues...
after upgrading to lwapp.... ap reboots often...
without RM21A.. upgrade to lwapp was fine...
balag
balag1986 Fri, 09/17/2010 - 05:28
Sure... i found a strange thing... that might be the clue here...
in the show tech of that ap with RM21A inserted.... see below...
interface Dot11Radio1
Radio AIR-RM21A, Base Address 001b.d479.ee10, BBlock version 0.00, Software version 5.90.11
Serial number: FOC11271LSG
Number of supported simultaneous BSSID on Dot11Radio1: 8
Carrier Set: Unknown (???)
carrier set is unknown.. i guess this could be the issue..
anyhow let me know your thoughts as well...
fyi... the customer using aps are in -E domain...
balag
Surendra BG Fri, 09/17/2010 - 05:27
  • Cisco Employee,
i was checking one of the case which i handled... we used the tool first but faced the same issue.. then tried with cli and it worked.... but later came to know that the modular ones does not work in this way when we use the tool.. tool needs either G or Either A not both... but CLI worked..
Surendra
balag1986 Fri, 09/17/2010 - 05:30
can u plz get me the case number?
i did not quite understand your comments.
balag
Correct Answer
Surendra BG Fri, 09/17/2010 - 05:53
  • Cisco Employee,
Surendra
balag1986 Fri, 09/17/2010 - 06:11
hmmm... ok..
so to resolve this... we need to use archive download command..
is that correct?
also did you get any tracebacks in the ap when it is rebooting often...
thanks
balag
Surendra BG Fri, 09/17/2010 - 06:14
  • Cisco Employee,
nope.. we i did not see any tracbacks.. ok.. if ur are getting the tracebacks.. then its AP crashing.. not just rebooting.. open up a tac case for if the customers Aps are generating tracebacks..
Surendra
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
